Backup creation fails on RUT241 since firmware RUT2M_R_00.07.15
Hello, I get the following error when trying to create a backup from the command line on a RUT241 with firmware RUT2M_R_00.07.15 (or newer) directly after a factory reset:
BusyBox v1.34.1 (2025-06-04 10:34:44 UTC) built-in shell (ash)
    ____        _    ___  ____
   |  _ \ _   _| |_ / _ \/ ___|
   | |_) | | | | __| | | \___ \
   |  _ <| |_| | |_| |_| |___) |
   |_| \_\\__,_|\__|\___/|____/
    Teltonika RUT2M series 2025
   Device:     RUT241
   Kernel:     5.15.180
   Firmware:   RUT2M_R_00.07.15
   Build:      18a177b964b
   Build date: 2025-06-04 13:00:37
root@RUT241:~# cd /tmp/
root@RUT241:/tmp# sysupgrade -b backup.tar.gz
Thu Dec 11 17:40:51 UTC 2025 upgrade: Saving config files...
Failed to create the configuration backup.
root@RUT241:/tmp#
Firmware version RUT2M_R_00.07.14.3 was fine, RUT2M_R_00.07.18.3 is still affected.
This is madness, sysupgrade requires an absolute path and cannot cope with a relative path:
BusyBox v1.34.1 (2025-10-28 06:59:39 UTC) built-in shell (ash)
     ____        _    ___  ____
   Device:     RUT241
   Kernel:     5.15.186
   Firmware:   RUT2M_R_00.07.18.3
   Build:      ec1ef51550e
   Build date: 2025-10-28 07:44:31
Fri Dec 12 12:25:41 UTC 2025 upgrade: Saving config files...
root@RUT241:/tmp# sysupgrade -b /tmp/backup.tar.gz
Fri Dec 12 12:25:50 UTC 2025 upgrade: Saving config files...
root@RUT241:/tmp#
The test was done directly after a factory reset.
Here is a RUT240 with latest firmware after a factory reset working just fine:
BusyBox v1.34.1 (2025-07-22 04:55:23 UTC) built-in shell (ash)
     ____        _    ___  ____
      Teltonika RUT2 series 2025
   Device:     RUT240
   Kernel:     5.4.291
   Firmware:   RUT2_R_00.07.06.19
   Build:      869421ab6a6
   Build date: 2025-07-22 06:03:22
root@RUT240:~# cd /tmp/
root@RUT240:/tmp# sysupgrade -b backup.tar.gz
Updating profile default
Tue Jul 22 05:07:57 UTC 2025 upgrade: Saving config files...
root@RUT240:/tmp#
Do you still need any assistance, or has the issue been resolved after performing the factory reset?
Nothing has been resolved, please read more closely. sysupgrade is broken on RUT241 with current firmware while it works fine on a RUT240 with a previous firmware generation. I tested everything right after a factory reset to rule out any side effects from a custom router configuration and so that you can easily reproduce on your end.
Sorry for the delayed response.
This issue has been relayed to our research and development department, once I get feedback from them, I will get back to you.
Any updates? This issue has not been resolved …
I am still waiting for an update from our R&D team. As soon as I receive more information, I will let you know.
Thank you for your patience.
