Aveva and s7 1200 by RUT955
Required configuration for communication between s7 1200 and aveva scada by rut955
To understand your setup and provide guidance and the required configuration details, could you please share a bit more information about your intended use case, specifically:
  • What are you trying to achieve with this communication setup?
  • Could you provide a simple network topology or diagram showing all devices involved?
  • Which communication protocols are you planning to use (e.g., Modbus TCP, Profinet, MQTT, etc.)?
  • How should the data flow between the PLC, RUT955, and AVEVA SCADA (e.g., direct TCP or RTU connection, via VPN, etc.)?
Communication between AVEVA and s7 1200 by sidirect tool in aveva through Sim card in the modem
I believe it use profinet protocol
Communication between RUT955 and plc by ethernet
Could you please share some screenshots from the SiDirect tool in AVEVA? It would also be very helpful if you could provide a simple diagram with a short description of your intended setup so we can better understand your configuration. We are not very familiar with the SiDirect tool and AVEVA SCADA systems, so this additional context would be valuable.
It might also be worth checking similar setups, such as the one described in the thread linked below, as it might offer some useful suggestions or help clarify whether you’re trying to achieve something generally similar.
Regarding the communication between the RUT955 and the PLC via Ethernet, you simply need to ensure that the PLC is configured to use the RUT955 LAN IP as its default gateway, that the subnet mask is correct, and that the PLC and router are within the same subnet.
Could you also clarify what data you would like to collect from the PLC and how it should be processed or sent?
Furthermore, please take a look at the following tutorials/guides if you haven’t already:
I believe you’ll find some useful information or clarification for the setup you want to achieve.
