Auto run scripts via USB Stick in RUTX11
I have added some custom scripts to my RUTX11 router. The problem is that after a factory reset, all of these custom scripts are removed.
I am looking for a way to automatically restore them. Is it possible to use a USB flash drive containing the required scripts and configuration files, so that when the USB is inserted into the router, the scripts are automatically executed and recreated on the router?
Ideally, I would like a solution where, after a factory reset, I only need to insert the USB stick and the router automatically reinstalls the necessary scripts and settings without manual intervention.
Has anyone implemented something similar on a RUTX11 or other Teltonika routers? Any suggestions would be appreciated.
Good day.
Please post your questions regarding RUT devices in separate Networks group forum. Thank you for your understanding. Here is the link: https://community.teltonika.lt/c/teltonika-networks/5
Kind regards.
