We’re writing a web app that is using the RutOS API, but I can’t see an endpoint that would let us read/write our custom uci config?
Do should we write a vuci-app-xxxx-api? And if so, how do we handle multiple config section types, as the vuci-app-example-api only has one section.
Matas
5
The RutOS API documentation can be found here: https://developers.teltonika-networks.com/
What are you specifically trying to read or write when it comes to configuring? I don’t believe there’s an uci endpoint as I was unable to find one, perhaps if you’re trying to configure, say, Modbus for example, you should use the Modbus config endpoint (example) here: https://developers.teltonika-networks.com/reference/rutc50/7.16.3/v1.8.3/modbus#post-modbus-client-tcp-config
system
Closed
6
