API Rate Limit, Too Many Requests
Hello Teltonika RMS Support,
We are building an integration against the RMS API and have hit the account-wide request quota, which we were not previously aware existed. All of our API calls are now rejected with 429 Too Many Requests, which has blocked our development work.
What we are seeing
  • Every request to https://api.rms.teltonika-networks.com/devices?limit=100&offset=0 returns 429, and the response is slow or hangs before it arrives.
  • The same data loads normally when we open the URL in a logged-in browser session, so the problem only affects calls made with our API token.
  • Our last successful poll was on 24 Oct 2026, and the first 429 we logged was on 27 Oct 2026.
  • We manage 352 devices. Because RMS returns at most 100 devices per request, one full fleet refresh takes 4 requests.
Could you please reset (or replenish) our API request quota now - or, at minimum, grant us a small allowance, so we have enough requests to build and test the new integration? Once it’s in place our usage will stay comfortably under the limit.
Thank you very much for your help.
Kamol.b
