API credentials
i am a beginner on this device.
Im trying to access the APi on a Teltonik RutX50 version 0.7.6.1 to first of all get a token.
Is there any c# examples that i can look at?
Im trying to get the token but it fails.
Im expecting a json formatted string that i can deserialize but get only get a text string.
Am i failing on defining content-type?
Best regards
Hi Mange,
AFAIK the Content-Type is text/plain in the Headers.
I believe you’re referring in theJSON-RPC monitoring to get the session token? If so, you can follow the tutorial json-rpc and adapt it for C#
Hi, thanks for the answer.
I just wanted to show what kind of answer i get so i have cut out a small part.
\u001f?\b\0\0\0\0\0\u0002\u0003?UMo?8\u0010??W??8\u0001\"1q??YH?]dshQ?E???TP?H?&??H?Q??w$???\u001e?`yh?<?y?HgO?y}???;V???d?\u00173?Vy\u00046Z?
What is that format?
kind regards.
