There is a assoclist field in the /wireless/interfaces/status endpoint. It’s defined as object and everything is fine when there is at least one item in the object. Problem is when there is no client connected and the map is empty. In this case API should return empty object {}, but it returns empty array [].
I’m writing a Prometheus exporter, so I need to parse the response and it’s super annoying mistake, because I have to cast everything from the object manually.
Apologies for any inconvenience this issue may have caused. I have reported the matter to our RnD team, and I will inform you as soon as I receive their feedback.
