Another connection in the same web browser cause exit from previous WebUI session
There is some problem with access to two or more WebUI from the same web browser. Another connection brake previous WebUI connection. I don’t know it is problem of Chrome web browser, or the design of your WebUI. But when I do the first device (RUT951) connection e.g. from Chrome and the second device (TWS212) I connect from Brave, I can use the both WebUI without any exception parallely. When I make both connections to RUT951 and TWS212 from the same browser, the second one cause unlogging the first session of WebUI.
Thank you for reaching out and describing the behaviour.
To help us better understand your setup, could you please clarify the following:
  • How are you accessing the devices’ WebUIs: directly through their local IP addresses, through RMS, or via another remote access method?
  • Are you using different IP addresses for each device, or the same IP address with different ports?
  • Are the RUT951 and TSW212 connected to each other? If so, please briefly describe how they are connected within your network.
  • Which firmware version is currently installed on each device?
  • Does this behaviour occur only with these two devices, or have you also experienced it when accessing other devices’ WebUIs?
Thank you for your cooperation.
T.
Hello T,
please find my clarification inserted as italic texts bellow.
MST
Thank you for providing the additional details.
I have tested this in our environment but have not been able to reproduce the reported behaviour so far.
It may be related to how the browser handles session cookies when accessing the same IP address through different ports. Browser extensions or stored site data could also be contributing factors.
Could you please confirm whether the issue still persists? If so, please try accessing both WebUIs from another PC or phone using the same connection method and let us know whether the behaviour occurs there as well.
T.
yes, the problem still persists. It behaves the same way on another computer as well.
As soon as I log from Chrome browser in to TWS212 in the second window, the connection to RUT951 in the first window immediately crashes, and the message “Your session has expired, please log in again” is displayed.
Only if I connect to the RUT951—for example, using the Chrome browser—and to the TSW212 using the Brave browser do both devices work simultaneously over the same connection without any problems.
MST
I would like to clarify that the same problem persists even after upgrading to the latest firmware versions, RUT9M_R_00.07.24.8 and TSW2_R_00.01.11. However, this only happens when accessing via port forwarding. When connecting directly via local IP addresses, multiple WebUI connections do not interfere with one another, even when I access them from the same browser, such as Chrome. So this is probably something related to the port forwarding feature or possibly the firewall itself.
Thank you for the update and the additional details. I have replicated this behaviour on my setup.
I will clarify this with our R&D department and update this thread once I receive their response.
T.
