I want to be contacted by AndzejJ from the old forum.
He was helping me with a wifiproblem on a Rut241. Then the old forum was shut down.
He knows all the details on my case, so I really want him to contact me
Hi MikaelJ,
Apologies for the late reply.
Since the access to the old forum is lost, could you please remind me about the current situation with the WiFi?
Hi. Sorry about the old forum.
Iām the one with a Rut241, having problem with wifi sometimes disconnect internet only on my tablet but all other devices working perfect.
Because the old forum is gone I will do a quick reminder about the problem.
When I run all my other devices on the network itās no problems at all. But when I connect my tablet, sometimes the wifi become connected but no internet. And if other devices are connected when this occurs, the same happens with them. Sometimes it reconnect internet by it self, sometimes by switching wifi on/off on tablet, sometimes it says ācouldnāt connect because of authentication problemā and i have to reboot router by power of.
You couldnāt see any problems in the troubleshootfiles. Iāve tried a lot of different settings. I had the same problem with another tablet, but both works perfect with another router or with my phone hotspot. Iāve tried a simcard with another mobile operator, that didnāt solve the problem.
The tablet has been for service 3 times but they donāt find anything wrong, tablet works fine when theyāre testing.
In the last message in the old forum you said that I should try different encryptions for wifi, did that, even tried with no encryption at all, that didnāt solved it either.
But I have some new information. Iāve noticed something strange. The tablet are android (12). YouTube is already installed in the tablet from the beginning, and the problem never occurs when I streaming YouTube. It occurs when updating Google play apps. Or for example streaming Netflix, intalled from Google play. I did disable Google play protect to see if there was any difference, but no.
Any ideas about this?
Another thing Iāve been thinking about. Could it be something in the firewall in the router that causing problems?
To clarify. Iām starting to suspect that thereās something weird in the communication between android 12 Google play and the router.
Iāve borrowed a tablet with older android (9) and that worked perfect. My phone is android 11 and my TV also older android version, and they have no problems when connected.
The other tablet i had and my current are android 12, both had problems when connected to the Rut241, but not other networks.
One more thing Iāve noticed is that when i updating Google play apps or using apps installed from Play store, like Netflix and are connected to the router internet speed is slow. But with YouTube itās fine again.
When i connect my phone to the router and updating Play store apps the speed is fast. Also when I connect tablet to phone hotspot and updating Play store speed is fast.
I know this sounds weird, but this is whatās happening.
If you havenāt made any changes to the Firewall settings, everything should be working fine. It is difficult to determine the exact cause of this specific issue, since it occurs only with a specific device when it is using specific applications.
Have you tried using an older firmware version like 7.02.7? You can download a backup file, downgrade via the bootloader, and check if the connection becomes more stable with the older firmware.
I assume you have tried different settings on the wireless interface, like increasing the DTIM interval.
To gather additional debugging information for your Wi-Fi, you can execute the following commands through the CLI and view the logs:
The logs should provide more details. If you decide to share these logs, remember to blur any sensitive information for privacy reasons.
You may try lowering the MTU on the mobile interface, though I do not think that this will help.
Also, there should be a decent amount of general WiFi fixes in the v7.5 version for RUT241. I would recommend updating whenever v7.5 releases to check if the new firmware resolves this issue.
Hi
I have experimenting with different settings in the firewall, but after that Iāve done a factory reset, to ensure settings are at default. Yes Iāve tried different settings in wireless, and MTU in mobile.
I have tried every firmware version since the first one. The seller of my Rut241 send me another router to see if mine was broken, but the new had the same issue.
Iāve tried a simcard with another operator.
I live on the countryside, with only one neighbour. So the chances of interference from other networks are at minimum (Iāve tried different channels).
Like I said the problem only occurs with two tablets, both android 12, but different brands (Samsung and Acer). Both tablets works fine with other routers and networks.
All my other devices works perfect with my Rut241.
This problem is so mysterious and itās making me crazy, I have had this problem since I bought the router 6 months ago. If I havenāt been so stubborn Iāve given up a long time ago.
Well I will be waiting for the new firmware update and hope the problem is gone.
Hi again.
I found a hidden wifi developer options mode on my tablet.
Where you for example can find wifi and network information, and perform diagnostics. Diagnostics looks fine when Iām connected.
There where also router specific history. I can see a lot of disconnections and reconnections, like I experience. New and interesting information was that sometimes the disconnections only lasted for a few seconds, these disconnections isnāt noticeable when using tablet. But maybe that can be the explanation to why internet is slow on the tablet, but not on other devices.
In the history log I also noticed that sometimes when the tablet tries to reconnect it says:
DISCONNECTED
TRY_TO_CONNECT
ASSOC_REJECT
TRY_TO_CONNECT
DHCP
CONNECTED
Or this:
DISCONNECTED
TRY_TO_CONNECT
L2_CONNECT_FAIL
TRY_TO_CONNECT
DHCP
CONNECTED
What does it mean, ASSOC_REJECT and L2_CONNECT_FAIL?
Then i connected the tablet to my phone hotspot network. And of course there where no disconnections at all in the history log. Tablet works perfect with my phone hotspot or other networks Iāve tried. Also service shop didnāt find anything wrong when testing it.
Do you know when the new firmware version will be released?
It appears that your tablet is experiencing various WiFi errors, like failed authentication/association and L2 errors, despite not changing the passphrase and trying different authentication methods. These issues might suggest a compatibility problem at a lower L2 layer between the two devices.
I assume your tablet is running the latest Andoid version available for your device?
As of now, the release date for v7.5 is uncertain. The original planned release date was postponed, and several fixes and features were included in v7.4.4 instead. However, the WiFi improvements for RUT241 should be included with v7.5.
Hi
Is there anything to do in settings to fix this?
Yes the tablet is updated.
Iāve had the same problems with two different android 12 tablets now, itās so strange that no one else experience same problem.
Iāll wait for v7.5. and keep you informed.
Thanks for the help
Same Problem here with Apple products (iPad, iPhone, MacBook Pro)!
Can you please provide more details about your issue?
What router are you using? What firmware version is installed?
Also, please provide some system logs after the issue has occured. System logs can be found in System ā Administration ā Troubleshoot by pressing the āviewā button. Before posting logs here, ensure that you hide sensitive information, such as IP addresses, serial numbers, etc.
Iām using an RUT241, Firmware RUT2M_R_00.07.04.5.
The Problem is, WLAN connection again and again is interruppted on devices. When trying to reconnect, the devices tell me that the connection cannot be established. After a router reboot it works again.
I can send you a troubleshoot file - but Iām not able to upload here?
THX
Do all devices experience these issues or does it occur only on some of them? Maybe you have noticed any patterns as to when it happens? What applications or devices are used when the issue occurs?
There is no option to send files privately. Thus, please, āviewā system logs from the troubleshoot page, copy the latest logs, hide sensitive information, and post them here.
The issue mostly apperars when watching videos on iPad (I think so). After a view minutes, wireless connection disconnects.
The problem also appears when connecting to our headquarter by VPN (MacBook Pro).
Currently Iām not on site. Iāll post the logs as soon as Iām back on site (maybe this friday).
Sure. Just post the logs here whenever you will be able to get them.
I did some tests today. At about 20:45 I get disconnected from WiFi - see logs:
Sun Aug 13 20:38:01 2023 kern.notice ssidname: WiFi client connected: C4:C3:6B:6D:6D:EF
Sun Aug 13 20:38:01 2023 daemon.info hostapd: wlan0: STA c4:c3:6b:6d:6d:ef RADIUS: starting accounting session 02B6314ED1F99E80
Sun Aug 13 20:38:01 2023 daemon.info hostapd: wlan0: STA c4:c3:6b:6d:6d:ef WPA: pairwise key handshake completed (RSN)
Sun Aug 13 20:44:13 2023 daemon.info hostapd: wlan0: STA c4:c3:6b:6d:6d:ef WPA: group key handshake completed (RSN)
Sun Aug 13 20:44:13 2023 daemon.info hostapd: wlan0: STA e6:2e:34:9f:2f:6d WPA: group key handshake completed (RSN)
Sun Aug 13 20:44:13 2023 daemon.info hostapd: wlan0: STA a2:91:93:70:e5:c1 WPA: group key handshake completed (RSN)
Sun Aug 13 20:44:14 2023 daemon.info hostapd: wlan0: STA 8e:df:cd:07:41:8d WPA: group key handshake completed (RSN)
Sun Aug 13 20:44:14 2023 daemon.info hostapd: wlan0: STA 32:34:c9:9d:ba:78 WPA: group key handshake completed (RSN)
Sun Aug 13 20:46:10 2023 kern.warn kernel: [396788.868524] sched: RT throttling activated
Sun Aug 13 20:47:05 2023 daemon.notice hostapd: wlan0: AP-STA-DISCONNECTED c4:c3:6b:6d:6d:ef
Sun Aug 13 20:47:05 2023 kern.notice ssidname: WiFi client disconnected: C4:C3:6B:6D:6D:EF
Sun Aug 13 20:47:05 2023 daemon.notice hostapd: wlan0: STA c4:c3:6b:6d:6d:ef IEEE 802.11: did not acknowledge authentication response
Sun Aug 13 20:47:12 2023 daemon.info hostapd: wlan0: STA c4:c3:6b:6d:6d:ef IEEE 802.11: authenticated
Sun Aug 13 20:47:12 2023 daemon.info hostapd: wlan0: STA c4:c3:6b:6d:6d:ef IEEE 802.11: associated (aid 1)
Sun Aug 13 20:47:12 2023 daemon.notice hostapd: wlan0: AP-STA-CONNECTED c4:c3:6b:6d:6d:ef
Sun Aug 13 20:47:12 2023 kern.notice ssidname: WiFi client connected: C4:C3:6B:6D:6D:EF
Sun Aug 13 20:47:12 2023 daemon.info hostapd: wlan0: STA c4:c3:6b:6d:6d:ef RADIUS: starting accounting session 3D8A9618D16001E5
Sun Aug 13 20:47:12 2023 daemon.info hostapd: wlan0: STA c4:c3:6b:6d:6d:ef WPA: pairwise key handshake completed (RSN)
Sun Aug 13 20:47:13 2023 daemon.info dnsmasq-dhcp[3590]: DHCPREQUEST(br-lan) 192.168.10.151 c4:c3:6b:6d:6d:ef
Sun Aug 13 20:47:13 2023 daemon.info dnsmasq-dhcp[3590]: DHCPACK(br-lan) 192.168.10.151 c4:c3:6b:6d:6d:ef devicename
Could you check if watching the videos on a lower quality still results in the same behavior? Try with 240p, 480p, 720p and so on.
Are you asking me or āmittererrā?
When the issue occurs again, could you please run the following commands from the command line and share the output?
iwinfo wlan0 scan
iwinfo wlan0 assoclist
iwinfo wlan0-1 assoclist
dmesg
Before sharing the results of the scan, make sure to hide any sensitive details like MAC addresses.
Hi
Iām sorry, I donāt understand how to do that.
Could you explain?
