Analog Input Value Between Device and RMS
I have a RUT956 that I am using to monitor temperature. I have an RTD analog out connected to the analog input of the 956. Modem works great, reading correct values of close to 28 degrees C. I have monitoring templates on my RMS platform where I am logging the temperature twice daily. The problem is the reading in RMS is 24 degrees C. Can anyone help me figure out the issue here? This is a small pilot project I am looking after, and I have three devices operating in a very similar manor, two identical. One giving me grief, the other appears to be reporting correctly. Both using same monitoring template.
