Hello Team, I use only sim mobile with my RUTX11 and after update to last firmware 07.14.3 I cannot use bitdefender vpn as usually.
I try to change wan connection IPv4/IPVP6 or only IPV4 again and again but nothing changing. Router block ports when I try to use anyone vpn of Bitdefender and I cannot navigate in banking or else.
I need your help as soon as possible.
Thank you
Hello @Fax,
Thank you for reaching out. To better understand your setup and the VPN issues you’re experiencing, could you please clarify a few details:
- Which VPN protocol does Bitdefender VPN use in your case? I assume it’s OpenVPN, but please confirm.
- If possible, could you provide a simple network topology or a description of how your devices are connected and where the VPN fits in?
- If you’re connecting your RUTX11 as a VPN client, could you share any logs available under Services → OpenVPN?
- Could you confirm whether everything was working properly with the previous firmware version before updating to 7.14.3?
Looking forward to your reply.
Hello Martynas
- Which VPN protocol does Bitdefender VPN use in your case? I assume it’s OpenVPN, but please confirm. - EVERYTHING
- If possible, could you provide a simple network topology or a description of how your devices are connected and where the VPN fits in? - ON EVERY PC ON THE LAN, I HAVE 4 PC ON CABLE -
- If you’re connecting your RUTX11 as a VPN client, could you share any logs available under Services → OpenVPN? I DON’T USE SERVICES OF THE ROUTER BECAUSE I DON’T HOW TO CONFIG IT - I USE BITDEFENDER ONLY AS VPN
- Could you confirm whether everything was working properly with the previous firmware version before updating to 7.14.3? BEFORE ONLY SOMETIMES, BUT I COULD CHANGE IPV4 ON IPV4/IPV6 AND COME BACK TO IPV4 AND EVERYTHING WAS GOOD - Now I think there IS some problem on ports but I don’t how to solve it
Thank you
Hello @Fax
Thank you for the update. I believe, to assist and understand your issue effectively, we’ll need to continue this process privately. You should find a support request form in the inbox of the email address you used for your forum registration. Kindly fill out the form, and please reference Ticket ID: 13998 when submitting it. Once the form is completed, we’ll contact you directly via email to investigate the issue in detail and help work towards a solution.
ok. Thank you so much
