I know the only way to reset without a RMS account is a factory reset, as I have the configuration backed up im ok with doing this.
But as soon as I reload the config file for the the restore it brings back the forgotten password as well.
Anyway to restore from back up and not chnage the admin password back or export the bulk of the config infomation to save hours on resetting up my router?
I didn’t quite understand your request fully and I’d like to clarify:
Are you referring to forgetting the default admin password, located on the back of the device or the current admin password set on the device?
Regarding your question about configuration restoration, it is not possible to restore the default admin password when uploading a backup. In your case, a factory reset would be required to reset the admin credentials.
