Access to router after bridging
Hej,
I am using two Teltonika routers for an engineering project where one router (RUTM10, IP 192.168.5.1) is set to bridge its LAN ports to the Wifi of rouyter 2 (RTUX50, IP 192.168.1.1). I followed the instructions here: RUTOS relay / Wi-Fi extender / repeater / bridge configuration - Teltonika Networks Wiki?
Now, RUTM10 is given its IP by RUTX50. This is also fine, but I want to change settings of the bridging router now and I can’t access the configuration page under this IP address (192.168.1.157) or its wifi interface.
How can I access the router after having set the bridging? I am happy for any help and feel quite stupid.
Erik
Simply try and set your computer’s IP to a static IP address, which would be on the same subnet as the device that you are trying to access. It would look something like this:
As 192.168.1.157 IP address is received on WAN interface you’ll need to enable remote SSH/HTTP/HTTPS access in WebUI → System → Administration → Access control to be able to access router via this IP. I suspect that ping to 192.168.1.157 works with current configuration?
Hi, that unfortunately didn’t help. But thank you :slight_smile:
Thank you very much :slight_smile:
