The DAP140 or RUTM10 for example, i know k/v can be enabled on AP mode but my question is if on STATION mode k/v frames are actually used.
Teltonika routers in wifi STATION mode uses the info provided by 802.11k and v for enhance roaming process?
I understand in AP mode you can select whether to enable these protocols but in STATION mode these options disappear from the roaming tab on the web ui, so i assume k/v are always taken in account on STATION mode.
This question comes because other brands like Mikrotik or others on STATION mode indeed receive the frames related to 802.11k/v but doesnt do anything with them.
On the AGV/AMR field taking in account k/v info improves greatly the roaming feature which is critical in these enviroments to maintain a good quality wifi connection.
