Hi everyone.
I have a problem with RUTX50 routers if they join a 5G NSA networks.
The router loses its mobile connection after some minutes, then remains offline for a few minutes (maybe 5 minutes), followed by an attempt to re-establish the connection (successfully).
The mobile connection (5G NSA) is then stable for a few minutes, then breaks off again.
The SIM card is locked and the RutOS-Web-UI says you have to unlock the SIM PIN manually even though the PIN entry is correct and stored in the config.
If only 4G connections are permitted, the mobile connection is permanent and stable.
Firmware used: RUTX_R_00.07.09.3
SIM slot used: SIM 2
Provider, operator: vodafone.de, Germany
Modem type according to RMS: Quectel RG501Q-EU
Modem firmware: RG501QEUAAR12A11M4G_04.200.04.200
5G band n28 (according to the community this has caused problems in the past) has already been excluded, the problem still exists.
In my example the RUTX50 uses multi-carrier aggregation.
LTE B1, B7, B20 and 5G N78 are aggregated at the moment. 5G N78 seems to be unreachable from time to time. So it comes and goes.
The Router is inside a building in the city of Berlin. The cellphone tower for 5G is around the corner.
Connection was broken at around 9:28 a.m. 3G/4G/5G leds were flashing, web UI shows “SIM 2 is locked, please provide PIN…”, “Data Connection Disconnected”, event log entry shows “Mobile Data disconnected (internal modem)”.
Automatic reconnection of the mobile connection (without the PIN being manually unlocked) 5 minutes later. Event log entry then shows “Mobile data connected” and subsequently “Joined 5G-NSA network (internal modem)” etc.
I have been able to download troubleshoot files and syslog. A screenshot of the RMS metrics site can give an impression on how instable the mobile connection is when using 5G network and how stable it is only using 4G network.
Inside the syslog it seems that the GSM process triggers the automatic reconnection.
I can’t find a file upload here. As I said, I can provide helpful files.
My problem looks similar to the issues described in this thread RUTX50 5G connection dropout (att. AndzejJ) - #107 by DelphiC
but I am creating a new topic for it has been requested.
I already wanted to contact helpdesk directly but it seems that I can’t log in nor reset my password over there.
Looking forward for your help.
Kind regards.
Jakob
