4G Router Bridge Mode SMS Gateway Internet
Hi all.
Is there a way to give the router direct outgoing access to the Internet when the mobile is in Bridge mode? Or is my only option Passthrough mode, which I am not too familiar with.
I am currently getting the Internet IP in my main router, which I would prefer to keep if possible, but SMS Gateway wont work as the Teltonika has not internet connection.
Thanks.
Passthrough mode will be the best option here, as it will provide the public IP to a specified LAN device, but the router and other LAN clients will still be able to access the internet from the assigned private IP addresses.
The main difference between bridge and passthrough modes is that the bridge mode simply forwards the DHCP lease to a connected LAN client, while passthrough mode does the same, but both the router and remaining LAN clients can access the internet using the same IP address.
Hope this helps!
