2 TRB500 still match slower download then my Smartphone
Since my first case was closed on February 9th, I’m opening this one.
I saw in another customer’s case with 5G problems that there is a newer modem firmware RG501QEUAAR12A11M4G_04.200.04.200 than my currently installed RG501QEUAAR12A09M4G_04.200.00.000. I would like to try this, or better, the latest one if available. Could you please send me the download link for both firmware so that I can go back in case of an error?
I’m surprised that these aren’t on the homepage.
Regards Thomas
I have sent you a form to fill out. Once completed, I will contact you privately and provide modem firmware version file. Please use ticket ID “7648”.
Also note that when you use “passthrough” mode (and possibly also “bridge” mode) you cannot get more than about 250Mbit/s for now. I reported that (and others did), and they are looking into the issue.
I had to select NAT mode to work around this issue.
At the moment I have 100 with the TRB and 150 with the mobile phone. And that in both modes NAT or passthrough
Ok that is indeed slow… we have modem firmware RG501QEUAAR12A08M4G_04.200.00.000 and we have 5G with band N78 and it gives 250Mbit/s in passthrough mode and 650Mbit/s in NAT mode, while the network itself has >1Gbit/s performance on other devices.
that sounds like wrongly set mtu
try
or on Windows
netsh interface ipv4 show subinterfaces
netsh interface ipv4 set subinterface Ethernet mtu=1464 store=persistent
netsh interface ipv4 set subinterface wifi mtu=1464 store=persistent
you can check with wireshark
Regards Tom
