Hi i have bought a RUTX50 riuter for my motorhome, my question, i want to conect to 12v but there are 4 wires coming from the 12v cable. do i just connect red and black to pos and neg and disregard the other 2 cables, green and white? I dont understand why there are 4 wires.
Thank you for reaching out.
If you only need to power up the router, connecting the positive (red) cable to the first power socket pin and the negative (black) cable to the second pin will be sufficient. The other two cables (green and white) correspond to the remaining pins (3 and 4) and are used for input and output. These are intended for monitoring and controlling connected devices or receiving signals to trigger specific events.
For more detailed information on the RUTX50 powering options, you can refer to this page: RUTX50 Powering Options.
