Witch modell Teltonika
Hi, i need an device to my boat with gps geofence and one or two output wire, whitch give 12volts about 1-2 seconds to relay. I connect relay to my ebersbrächer warmer to give it ON or OFF.
Can i drive warmer then by sms?
Which Teltonika modell is active to me?
Hello @Tg69
Good day!
You can use FMC230 for this use case https://wiki.teltonika-gps.com/images/0/06/DS-FMC230.pdf
