Which models have mqtt?
Hello and have a good time
I want to buy a tracker. But I don’t know which models have mqtt.
Please introduce models with mqtt
Hi @aminhorri,
Good day! On the recent Firmware version released, more Teltonika Devices have the MQTT support for AWS IoT Shadow/Custom and Azure IoT added.
Example FMC130.
FMC130: FMC130 firmware errata - Wiki Knowledge Base | Teltonika GPS
On the Wiki Page of each device, you may access the Firmware Errata where you can see the latest updates on the device Software.
To learn more about the Wiki Page, you may browse through on this link: Wiki Knowledge Base | Teltonika GPS
I hope this helps.
Patrick
thanks a lot.
fmb920and fmb120 and 122 have mqtt?
Hello @aminhorri,
Currently, the MQTT Base Firmware update on FMBXXX devices has not yet been released. However, it will soon be updated on the Base version where you can be updated via this link: FMB120 firmware errata - Wiki Knowledge Base | Teltonika GPS.
Patrick
ok thanks
i have Broker mqtt .
i can use my broker?
or just use AWS and Azure?
As of now, Teltonika devices support AWS and Azure, so other cloud platform is not yet supported, in case you want other cloud platforms to be supported, you need to contact your sales manager.
Patrick
