What is the best configuration forfmc130 to avoid jumps and send data correctly . I just want a clean playback in system As much as possible.
Hello @rezk_msa
The GPS jumps may occur not only when the configuration is incorrect,
It can also happen when satellite coverage is unavailable, causing the device to lose gps signal connectivity,
Another reason could be if the firmware is old,
Additionally, if the device is not mounted in the recommended position
To make device performance stable
- Device should position and mounted as recommended in link Mounting recommendations - Teltonika Telematics Wiki
- Make sure the firmware is updated. You can download the latest version from the provided link Firmware versions - Teltonika Telematics Wiki
Regarding the configuration, you can enable the Static Navigation Filter in the system’s setting, FMC130 System settings - Teltonika Telematics Wiki , as this will help to filter out gps jumps when the vehicle is stationary, and keep the Records Saving/Sending Without TS configured on After Position Fix
Regards
Maryam
This topic was automatically closed after 9 days. New replies are no longer allowed.
