Value for changing the Movement Source with GPRS
I need to know what the value that I need to send to the device to change the movement source to Ignition+Accelerometer
The command that I’m using is: setparam 138:[?]
What I need is the value that I need to send to set for Ignition+Accelerometer.
Thanks!
Hi Bruno,
Please refer to respective device’s parameter list to see check what values should you choose. Refer to parameter list of FMC130 as follows (for reference) - FMC130 Parameter list - Teltonika Telematics Wiki.
When selecting multiple options, add the values e.g.:
  • Ignition (1) + Accelerometer (2) = 3
  • Ignition (1) + Accelerometer (2) + GNSS (4) = 7
Thus, the final command in your case would be:
  • setparam 138:3
Hope this answers your question.
Junaid A
