Used RUTX50 not reachable. Is it bricked?
Maybe this topic could give you some ideas. If it is possible to obtain an uart connection I would try to boot the device with the added “init=/bin/sh” option to the bootstring. This will bypass the password stage and you’ll be able to change it on the fly. I’ve done similar things many times.
IMHO worth a try. You might need a 3.3V TTL to USB converter.
