Use Eye Beacon for Immobilization?
The CAN-Control can also be used for immobilizer ; however, it requires connection to the CAN-line of vehicle , also it needs to be connected to the vehicle according the the wiring diagram which will suppose to provided by Teltonika support for the correct setup.
Further you need to send commands for lock/unlock
Check the list of supported vehicle from link https://wiki.teltonika-gps.com/images/1/1a/CAN-CONTROL_IMMO_2024_05_15_en.xlsx
For immobilizer using the device only ,
  1. To control the engine, connect a relay to the DOUT and Din of the device.
  2. For authorization, you can connect an iBeacon.
Find the below wiring diagram for reference
Regards
Maryam
