HI again,
I was poking around the app and for March this month, it doesn’t show any data. It did for Feb.
Is there anything I can do to get that information?
Cheers,
Pat_B
HI again,
Cheers,
Pat_B
Make sure you are using the latest update.
Hello @Pat_B ,
Kindly check if the issue still persists or you are able to see the sessions after that specified date.
The data might have been missing due to “Factory Reset” pressed in the Installer menu.
Regards!
