2.1.4. actual version , need to update but from fotaweb no update possible any help |
hello
did you upload the FW to the FOTA?
if you are getting an error, kindly send me the screenshot
BR
laith
i dont have any firmware to upload to fota the onky firmware i found are i the upload menu and there us no new firmware to upload teltonika say to me only to send sms web_connect . on fota web ftc was in pending after the web connect command it change from pending to connecting and when it goes back on line and the software has been downgraded i need to install the 3.22
"timestamp": 1774335164,
"meta": null,
"response": "FOTA Pinger triggered!",
"id": 1774335163700769,
"command_id": 1774335163700769,
"max_attempts": 3,
"name": "custom",
"device_id": 7937613,
"executed": true,
"properties": {
"text": "web_connect"
"priority": 0,
"condition": "",
"expires": 0from flespi when i type command web_connect. you see response, "FOTA Pinger triggered!", the ftc is online on fotaweb and not in pending, i nee you to put it on pending mode so maybe he will accept the command web_connect
