I tried to pair my TeltoCharge EVC1200P4011 with smartphones (iOS and Android devices) but I can not pair to charger with any smartphone.The charger is in standby mode with default settings(Yellow pulsing LED‘s).
*Teltonica Energy app version : 1.10.0
That’s my list what I did ;
Try to pair with iPhone 11 (iOS version : 17.1) but issue persist
Reboot EVcharger but issue persist
Try to pair with Samsung SM-A52F (Android version :13) but still persist
After error notification, forgot EVcharger on Smartphones and try pair again but issue persist.
When you are trying to pair your devices, Note: charger can be paired only in a recovery mode. Charger goes into recovery mode for 5 minutes after every reboot. If security code was entered incorrectly for 3 times, pairing becomes impossible and charger has to be rebooted again.
( Şarj cihazınızı eşleştirmek için kurtarma modunu kullanmalısınız. Cihazı yeniden başlattığınızda 5 dakika süresince bu moda geçer. Eğer güvenlik kodunu 3 kez hatalı girerseniz, cihazı yeniden başlatmanız gerekecektir, baslattiktan sonra 5 dakika icinde eslestirme yapmaniz gerekiyor. Belki bunu unutuyorsunuz? Eger sorun cozulmezse tekrar yazabilirsiniz.)…
