Hello.
I would like to ask if there is any information regarding the FMM001 device, and the connection to Nissan NP300 vehicles. This as we have a request from a client that wants to be able to monitor the fuel level of his vehicle using this device, however we are not sure if such reading can be obtained from that vehicle company. The model of the vehicle is 2015.
Thank you.
Regards
Dear @Soporte_TesatelGPS,
Good day! FMM001 is a plug-and-play device that you may directly connect to the OBD socket of the vehicle. Meanwhile, refer to the link below to learn more about the device-supported vehicle list.
Supported non-electric vehicle list for FMB001, FMC001, FMM001: https://wiki.teltonika-gps.com/images/b/b8/FMX001_%2B_FMX00A_Supported_Vehicles_20240318.pdf
Supported electric vehicle list for FMB001, FMC001, FMM001: https://wiki.teltonika-gps.com/images/4/47/FMX003%2BFMX001%2BFMX00A_Supported_Vehicles_(EV)_20240318.pdf
I hope this helps.
Patrick
Thank you.
Although i could not find the NP300 model, i believe that the fuel value will be read, as most of the Nissan models show that the reading is available.
Best regards.
Hi @Soporte_TesatelGPS,
It seems that the Nissan NP300 was nearly the same as the Nissan Navara vehicle. I recommend you to test and check as the parameters you need might be available.
Patrick S.
