Hello everyone,
I have a problem with a teltonika device The device is powered on but when I connect to the computer to configure it, the interface does not detect the device connected. The firmware I am using is Teltonika.Configurator_Mobility_1.7.66_B.55.2_R.10.
Thank you in advance for your help
Kindly download the configurators for the same model from the link Firmware versions - Wiki Knowledge Base | Teltonika GPS Also, make sure you have downloaded the COM port driver, as without it, the device will not be detected by the system port https://wiki.teltonika-gps.com/images/d/d0/TeltonikaCOMDriver.zip
Regards Maryam
This topic was automatically closed after 13 days. New replies are no longer allowed.
