Teltonika Configurator Tool GH5200 Installation Problem
We have recently been given GH5200 device as a sample to test, the problem that I am running into is that when I try to run TCT according to the manual, I get this message
tel
When I click Yes, nothing seems to happen. The application just closes. Already have .NET Framework 3.5 and 4.8.1 installed, as well as .NET Core 6.0.31, and there seem to be no problems regarding them. Installed .NET Framework 5.0, no change. Restarted the PC, no change. Uninstalled everything regarding .NET and reinstalled it, no change as well.
How can I resolve this issue? Should I do something with the firmware file that was provided in the download before running the TCT?
TCT version used is 1.7.66_B.55.2_R.10, firmware version 55.02.03.Rev.05
TCT version 1.6.11 R.39 works, but I guess that the firmware versions may not be compatible, given that my GH5200 currently has firmware version 55.02.03.Rev.05
Hi @UrosPetrov
Please download this file: https://wiki.teltonika-gps.com/view/Special:Redirect/file/55.02.03.Rev.05_and_1.7.66_B.55.2_R.10.zip
You can also check this dotnet framework here: Download ASP.NET Core 5.0 Runtime (v5.0.17) - Windows x64 Binaries (microsoft.com)
Best Regards
Maynard C
This topic was automatically closed after 6 days. New replies are no longer allowed.
