Teltonika API for FMC003
can we extract all data from teltonika configurator about the device FMC003 features even in real-time without USB cable transfer ?
If by extracting the configurator data you mean the configuration file, then yes you can download the configuration file using FOTA Web by going into Devices, selecting your device, and then creating a Receive Configuration Task. If you want the device to connect immediately to FOTA Web send the web_connect command. This command will have the device force connect to FOTA Web.
hello @Naps101
the FMC003 devices designee to send the data over TCP, UDP or MQTT protocols via mobile network
it is not possible to extracts the Realtime as clear data by using the USB cable
