Teltonica FMM920
Hey, i have get fmm920 to my hydrocopter.
I would use it antitheft alarm system.
So how i can save about radius 200m round my copter. If somebody takes it and it goes out from that radius ; i must get alarm to my cellphone.
What is the right anroid app where i can use fmm920?
Can i configure fmm920 with app?
Do the app show a map where the copter moves if i get an alarm?
What is current consumption in hour, i have an 30ah 12v battery.
Juhani
Welcome to Teltonika Telematics Community Forum!
Please try to use the Autogeofence settings so that you will get notified when the vehicle enters or leaves the zone.
On Exit - Generate events after the tracker leaves the zone
On Entrance - Generate events after the tracker enters the zone
On Both -Generate events after the tracker enters or leaves the zone
Wiki page: FMM920 Auto Geofence settings - Wiki Knowledge Base | Teltonika GPS (teltonika-gps.com)
Another option that you can do for anti-theft solutions is to enable the unplug detection
Wiki page link: FMM920 Accelerometer Features settings - Wiki Knowledge Base | Teltonika GPS (teltonika-gps.com)
For the mobile application, you can use the FMBT app: FMBT Mobile application - Wiki Knowledge Base | Teltonika GPS (teltonika-gps.com)
Note: You can only configure basic configuration using this app and it is connected via bluetooth.
It does not support by FMBT app , this option should be implemented in your server or your own mobile app
For the battery details you can find it here: FMM920 General description - Wiki Knowledge Base | Teltonika GPS (teltonika-gps.com)
Maynard C.
Ok, but how i can switch alarm of before i myself go out from geofence area?
Otherwise i get alarm to my phone everytime i leave from geofense area.
Thanks Juhani
Thank you for reaching out to Teltonika Telematics Community Forum!
You will receive a notification on your server/phone with the AVL ID 175
1 - target left the zone
0 - target entered the zone
For the alarm, your developer should implement the logic of how long the alarm should be when you receive the notification from the auto-geofence.
