TeltoCharge EVC1 – stuck in boot loop, cannot connect via Bluetooth (Unknown error)
We are contacting you on behalf of our customer regarding a TeltoCharge charging station that is not working properly.
Device details:
  • Product: TeltoCharge EVC1, 11 kW, 3-phase, Type 2 socket
  • Product code: EVC110000000
  • S/N: 1157443026
  • MAC address: 388A21FABF8B
  • Batch No.: 045
Problem description:
  • After power-up, the LED indicators keep running continuously (white/yellow with green) and the charger never reaches standby mode. It appears to be stuck in a boot loop / continuous restart.
  • The customer cannot connect to the charger with the Teltonika Energy mobile app. When the app finds the charger, the connection fails with the error “Unknown error – move closer, restart the charger or check Bluetooth settings.” Because of this, the customer never reaches the step to enter the pairing code.
  • The charger is therefore locked and cannot be used for charging.
Steps already taken:
  • Connection attempted several times only via the official Teltonika Energy app, standing right next to the charger
  • Charger disconnected from power for about one month, then switched on again; the issue persists
  • Power cycle via the circuit breaker; no change
A short video of the LED behaviour and a screenshot of the app error are attached.
Could you please advise how to restore the charger to normal operation (e.g. a reset or firmware recovery procedure)? If the device is faulty, please let us know how to proceed with a warranty claim.
Thank you in advance for your help.
Thank you for reaching out.
The Wi-Fi connection issue reported by some iOS users earlier this year has been addressed in subsequent firmware and app updates. Connecting directly to an EVC2 charger via its local Wi-Fi access point from an iPhone running iOS 27 should now work as expected.
If you are still experiencing connection issues, please make sure that:
  • The charger is running the latest firmware version.
  • The latest version of the TeltoCharge app is installed on your iPhone.
  • You remain connected to the charger’s Wi-Fi network even if iOS displays a “No Internet Connection” warning.
  • You try forgetting the charger’s Wi-Fi network and reconnecting.
If the issue persists, please let us know:
  • The charger firmware version
  • Your iPhone model
  • The TeltoCharge app version
  • The exact step where the connection fails
We will be happy to investigate further.
Džiugas
