We have tried with two separate computers, installed the needed drivers, .NTE framework (tried a few different versions), as well as the Configurator SW itself. Tried with a few different micro USB cables too in case that was the issue. The TAT240 turns on, the LED blinks, but that’s about all that happens. The Configurator SW doesn’t find it. Any helpful tips what to try next or is my hardware broken?
try with another PC with windows 11
Please download the latest firmware and configurator through this link: Firmware versions - Teltonika Telematics Wiki
If the firmware version is different please check your device configurator here: Teltonika Configurator versions - Teltonika Telematics Wiki
Also install the comdriver for the teltonika device you can find it in our wiki page: TAT240 First Start - Teltonika Telematics Wiki
Here is the direct link: https://wiki.teltonika-gps.com/images/d/d0/TeltonikaCOMDriver.zip
If it didn’t work please check the USB port connection or the USB cable.
Best Regards
Maynard C
Thanks, this one did the trick. Would be nice to know that Windows 10 doesn’t work - or whatever the reason was. But a Windows 11 computer was able to connect to the device.
which version of the .Net framework worked for you on Windows 11? The wiki says 4.6.2 but this is not working for me. Thanks for your help.
