Hello, I have a Bluetooth fuel sensor and I would like to know the SMS commands to input the MAC address of the sensor into the FMC130 so that it can send the fuel data.
The command is
Connection 1
setparam 1202:(MAC Address ) f
Please find the wiki link below: FMB SMS/GPRS Commands - Wiki Knowledge Base | Teltonika GPS (teltonika-gps.com)
Best Regards
A question: When I configured the GPS for sensor readings through the configurator, I added a “preset” in that part of the image that you shows me. When I configure it via SMS, is there any way to add it? Or is there no problem?
Yes but you need to configure all the parametesr based on the preset, it would be easier if you use FOTAWEB to update the device configuration.
Example:
Select advanced in connection 1
Then send the commands to configure all paramters
It will be a long setparam commands.
Please follow this command structure base on our wiki page:
Best Regards
Maynard C
