SMS commands not working
I have a FMC920 which I configured on the configurator to monitor external voltage. All works fine but Im now trying to adjust the parameter (50083) value to lower the level that it sends an SMS. It doesnt respond to getparam 50083 or setparam 50083 (yes I have put 2 spaces in the SMS)
Ive tried testing it with other commands eg getparam 102 - gets a response. getparam 20105 - no response
Any ideas why 5 digit IDs dont appear to work?
hello
it should respond, we haven’t faced such issues before, Please try again with the following:
getparam 50083
don’t forget to add double space,
Note: please make sure that the FW is the latest
let me know the result,
I have tried getparam 50083 and again no response
However, Ive discovered that if I send getparam 50081;50083;50080 then I get a response for those 3 parameters!
I can adjust the settings by sending setparam with the 3 IDs and values, but if I try setparam 50083:12000 then no response!
Hello
Please make sure to use the latest FW Firmware versions - Wiki Knowledge Base | Teltonika GPS
On my side, I have tested it, and it was working fine, all the commands that you mentioned, have been sent in the same way and received a response,
