Hi.
We have FMC130 installed in over 25 vehicles. Some ibuttons were also installed. However, we lost the file where we had the details which trackers have ibuttons. Is there any SMS command to know if ibutton is installed on the tracker or not?
Hi.
You can retrieve the iButton configuration by sending the getparam SMS command to the device.
For example, if an iButton is configured in the first slot of the list, its parameter ID is 30000. You can send the following SMS to the device:
getparam 30000
If the iButton is configured, the response will include the configured iButton ID.
Naveen
