I have several FMT100 devices that cease immediately the ignition is switched off and do not report where they are located at that time. I have tried adjusting several settings with no luck. Can any-one offer advice on how to set up the fmt100 to ensure it reports it’s location to the server at ignition off please?
Kindly check the ignition priority in the IO settings.
Once the ignition is OFF, the device will switch the data acquisition settings to stop mode.
If the ignition priority is set to low, the device will not send this record immediately.
Please configure the ignition as high priority and operand as on change.
Naveen
Thankyou Naveen
I have made that change and will now test it.
Graham
