Setparam ID 2004 no update
I need to update FMM920, FMM, and FMC125, so I send Setparam 2004:XXX.XXX.XXX.XXX (leaving two spaces at the beginning), but nothing happens. It doesn’t update or give me an error.
If I enter getparam ID:2004, it gives me the correct value.
Do I need to enable something, or am I doing something wrong with setparam?
Thank you.
Hello @Mathiu,
I hope you are doing well. Here is the command structure that you should send from the device for SMS command.
Command:
setparam 2004:xx.xx.xx.xx
Patrick S.
