RUTX11 SDK 07.17.1 wireguard_watchdog missing
In your case there is no reason to switch. The ubus call are used just for a corner case ie if the DNS are restricted to the wg tunnel and it is down the wg set … command will obviously fail.
Same in my case, RUTC50 in my camper must keep the S2S VPN Tunnel to my Fritzbox.
I think you have to add:
chmod +x /etc/opt/wireguard_watchdog
In a camper as well, so will stick to the non bus config.
Thx a lot
Almost two months later and still no answer for the initial question …
I give up.
Goodbye.
@scsimodo
Whoops … forgot to add that bit … thanks, Mike
