To access the LAN of RUT241 via the RMS VPN Hubs, you will need to add a route to the subnet you’d like to reach. In your case, manual parameters of the route would look like so:
Once the route is added, make sure to enable LAN forwarding for your device:
If you still cannot reach the PLC when connected to the VPN Hub, try logging into the WebUI of RUT241, navigating to
Network → Firewall → General Settings and enable Masquerading on the LAN zone:It should be noted, that as this is a layer 3 tunnel, TIA portal might not be able to discover the device automatically, and it may need to be added manually by specifying the IP address of your PLC.
Hope this helps!
