Hello
I found out that if I set Activation timeout 3 min, Event timeout 3 sec , Threshold 0.22g , Angle 1 deg, Duration 1600. Teltonika sends me 2 sms , one right now and second sms after 1 min. I tried both settings on 2 teltonika FMC920 and FMB920 where is the catch ? I woul like to have only one sms. From where comes the second alarm ? I want to put the teltonika on the motorbike and I am testing if you move the motorbike. Other settings are default
Thank you
Best regards
Sašo
Good day, it seems the 1-degree angle is too small, try to increase the angle to at least 3 degrees to make and adjust the event timeout to 10 sec, kindly test and play with the device settings according to your requirements.
Reference: https://wiki.teltonika-gps.com/view/FMB125_Accelerometer_Features_settings#Towing_Detection
Best Regards
Maynard C
It is the same…allways 2 sms…SMS are the same text from towing options…parametrs in teltonika FMB920 are the same and I have a problem there too, allways 2 sms, I even try diferent GSM provider sim card, I have 2 teltonika FMB and FMC 920… must be some other parameter for 2 sms, is possible to see whitch events is guilty for 2 records ?
Thank you
Best regards
