Hi
I have few devices FMB130 that I have set SMS login and password and want to remove them and set them back to default with GPRS or SMS command. Is it possible? Thank you
If you want the default configuration please send the commands below:
defaultcfg
Not if you send this commands all settings will be erased and load the default settings.
Reference: FMB SMS/GPRS Commands - Teltonika Telematics Wiki
Best Regards
Maynard C
Hi, Thank you for your answer. I don’t want the default configuration of the device. I want the default configuration of the SMS login and password which is ‘empty?’. Is there a command for that? Thank you
