I am receiving an unknown AVL ID 275 data from one of the FMB920 trackers.
I can’t find this ID number in the documentation.
In what option can I disable this in the configuration?
Hello
The ID 275 is specified for the Escort LLS Temperature, which couldn’t be received from fmb920 ,
Please Update the device firmware and reset the configuration file
Download from link Firmware versions - Wiki Knowledge Base | Teltonika GPS
In case if issue persist then contact with Teltonika sales manager and provide with us the logs along with configuration file
If you don’t have any contacts with our Sale managers, please contact with them on our official website https://teltonika-iot-group.com/ and click on “Contact Us” button. When you will click, please fill out the form and submit it.
Regards
Maryam
Unfortunately, the firmware update to the latest version did not help.
Also, uploading the configuration from another tracker did not help.
Only sending the defaultcfg command (Load default configuration) helped to get rid of this incorrect AVL ID.
Doing it remotely was quite a challenge ![]()
