Question: Bluetooth device to identify driver and diable alarm?
I am looking into a fmc920 to track my car/motorbike.
Is there a way to use my Phone or some bluetooth beacon to disable a preset alarm (eg via geofence)?
So I would not need to disable it manually (via Text, etc.)
This is a private tinkering project. So I am looking at a limited budget :slight_smile:
Thank you!
Mathias
Good day, how to want to implement the scenario?
Which features you want to enable into the device?
Maybe the custom scenario firmware can help you : Custom Scenarios - Teltonika Telematics Wiki
Maynard C
Hey Maynard,
thank you for the quick reply.
The Custom Scenario looks like a good base to build the workflow! :grinning:
I am not sure what you are getting at… If you ask for my “alarm” features: I was thinking about using a relay to disable the vehicle (e.g. the fuel pump).
Is it possible to use a mobile’s bluetooth capabilities to trigger a scenario?
And if not, is there some other bluetooth device that could be used as a trigger?
The scenario I have in mind:
I have some bluetooth device that get’s detected by the gps tracker and allows me to start/run the vehicle (without any alarms). If the device is not detected an alarm is send and possibly a relay disables the vehicle.
Hello, You can try to use a beacon simulator and install it to your phone, once the beacon ID is detected create a logic using a custom scenario to trigger the DOUT or activate or deactivate it.
Another solution is to use an EYE beacon: EYE BEACON / BTSID1 - Teltonika Telematics Wiki
Best Regards
Maynard C
