Hello. I’m using FMC130 with LV-CAN200 in order to track a number of Dacia-s model Duster 2010. Data is sent to Traccar which generates trips based on parameters: Total mileage (counted) and trip odometer. The GPS is not used, program number for LV-CAN is correct. The problem is that parameter: Total mileage (counted) has values that are about 10% higher than the values displayed on the dashboard and trips are generated with a wrong number of kilometers which don’t match the real dashboard mileage.
Hi @Bogdanita
Good day, please find the details below.
- Total Mileage - is the odometer value that you can find the same from the vehicle dashboard.
- Total mileage (counted ) - is the odometer value when you first installed the CAN adapter into the vehicle.
- Please find the data sending parameter for FMC130: https://wiki.teltonika-gps.com/view/FMC130_Teltonika_Data_Sending_Parameters_ID
- In case that you have an issue with the Total mileage value, please try to do autoscan: FMB140 autoscan feature instructions - Wiki Knowledge Base | Teltonika GPS (teltonika-gps.com)
- Autoscan works with the new LVCAN200 and ALLCAN300 with p4 protocol.
- If you still get incorrect Total odometer value please contact your sales or create an HD ticket.
Best Regards
Maynard C
Thanks for your answer. I will follow your guide and I hope the problem will be solved.
