Overlapping Subnets between 2 RUTX12 IPsec VPN
And traceroute 192.168.42.85 from 192.168.42.140
RUTX12-1 (192.168.42.1/25):
ip -4 route show:
default via 172.16.4.1 dev eth1 proto static src 172.16.4.111 metric 1
default dev qmimux1 proto static scope link src xx.xx.xx.xx metric 2
default dev qmimux0 proto static scope link src xx.xx.xx.xx metric 3
10.10.0.0/24 dev br-LAN_B proto static scope link metric 6
10.19.0.0/21 dev br-lan proto static scope link metric 4
xx.xx.xx.xx dev qmimux1 proto static scope link metric 2
xx.xx.xx.x dev qmimux0 proto static scope link metric 3
172.16.0.0/24 dev br-LAN_K proto static scope link metric 7
172.16.4.0/24 dev eth1 proto static scope link metric 1
192.168.42.0/25 dev br-ifLan2 proto kernel scope link src 192.168.42.1
ip -4 rule show:
0: from all lookup local
100: from all lookup 100
220: from all lookup 220
1001: from all iif eth1 lookup 1
1002: from all iif qmimux1 lookup 2
1003: from all iif qmimux0 lookup 3
2001: from all fwmark 0x100/0x3f00 lookup 1
2002: from all fwmark 0x200/0x3f00 lookup 2
2003: from all fwmark 0x300/0x3f00 lookup 3
2061: from all fwmark 0x3d00/0x3f00 blackhole
2062: from all fwmark 0x3e00/0x3f00 unreachable
3001: from all fwmark 0x100/0x3f00 unreachable
3002: from all fwmark 0x200/0x3f00 unreachable
3003: from all fwmark 0x300/0x3f00 unreachable
32766: from all lookup main
32767: from all lookup default
iptables-save | grep -i ipsec:
-A zone_wan_postrouting -m policy --dir out --pol ipsec -m comment --comment “!fw3: Exclude-IPsec-from-NAT” -j ACCEPT
-A PREROUTING -d 192.168.42.128/25 -m comment --comment “mwan3 exception for ipsec” -j ACCEPT
-A FORWARD -p tcp -m policy --dir in --pol ipsec -m tcp --tcp-flags SYN,RST SYN -m tcpmss --mss 1361:1536 -j TCPMSS --set-mss 1360
-A OUTPUT -d 192.168.42.128/25 -m comment --comment “mwan3 exception for ipsec” -j ACCEPT
-A FORWARD -s 192.168.42.128/25 -d 192.168.42.0/25 -i eth1 -m policy --dir in --pol ipsec --reqid 1 --proto esp -j ACCEPT
-A FORWARD -s 192.168.42.0/25 -d 192.168.42.128/25 -o eth1 -m policy --dir out --pol ipsec --reqid 1 --proto esp -j ACCEPT
-A FORWARD -m comment --comment “!fw3: IPsec bypass for offloading” -m policy --dir in --pol ipsec -j ACCEPT
-A FORWARD -m comment --comment “!fw3: IPsec bypass for offloading” -m policy --dir out --pol ipsec -j ACCEPT
-A zone_wan_forward -p esp -m comment --comment “!fw3: Allow-IPSec-ESP” -j zone_lan_dest_ACCEPT
-A zone_wan_forward -m policy --dir in --pol ipsec -m comment --comment “!fw3: Allow-IPsec-Forward” -j ACCEPT
-A zone_wan_input -p esp -m comment --comment “!fw3: Allow-IPsec-ESP” -j ACCEPT
-A zone_wan_input -p udp -m udp --dport 4500 -m comment --comment “!fw3: Allow-IPsec-NAT-T” -j ACCEPT
-A zone_wan_input -p udp -m udp --dport 500 -m comment --comment “!fw3: Allow-IPsec-IKE” -j ACCEPT
iptables -n -L | grep -i ipsec:
ACCEPT all – 192.168.42.128/25 192.168.42.0/25 policy match dir in pol ipsec reqid 1 proto 50
ACCEPT all – 192.168.42.0/25 192.168.42.128/25 policy match dir out pol ipsec reqid 1 proto 50
ACCEPT all – 0.0.0.0/0 0.0.0.0/0 /* !fw3: IPsec bypass for offloading / policy match dir in pol ipsec
!fw3: IPsec bypass for offloading / policy match dir out pol ipsec
zone_lan_dest_ACCEPT esp – 0.0.0.0/0 0.0.0.0/0 /
!fw3: Allow-IPSec-ESP /
ACCEPT all – 0.0.0.0/0 0.0.0.0/0 policy match dir in pol ipsec /
!fw3: Allow-IPsec-Forward /
!fw3: Allow-IPsec-ESP /
ACCEPT udp – 0.0.0.0/0 0.0.0.0/0 udp dpt:4500 /
!fw3: Allow-IPsec-NAT-T /
ACCEPT udp – 0.0.0.0/0 0.0.0.0/0 udp dpt:500 /
!fw3: Allow-IPsec-IKE */
ip -4 route show table 220:
192.168.42.128/25 via 172.16.4.1 dev eth1 proto static src 192.168.42.1
RUTX12-2 (192.168.42.128/25):
ip -4 route show:
10.10.0.0/24 dev br-LAN_B proto static scope link src 10.10.0.1 metric 5
10.19.0.0/21 dev br-lan proto static scope link src 10.19.6.1 metric 7
xx.xx.xx.xx dev qmimux0 proto static scope link src xx.xx.xx.xx metric 3
172.16.0.0/24 dev br-LAN_K proto static scope link src 172.16.0.1 metric 4
192.168.42.128/25 dev br-ifLan1 proto kernel scope link src 192.168.42.129
ip -4 rule show:
-A PREROUTING -d 192.168.42.0/25 -m comment --comment “mwan3 exception for ipsec” -j ACCEPT
-A OUTPUT -d 192.168.42.0/25 -m comment --comment “mwan3 exception for ipsec” -j ACCEPT
-A FORWARD -s 192.168.42.0/25 -d 192.168.42.128/25 -i qmimux0 -m policy --dir in --pol ipsec --reqid 1 --proto esp -j ACCEPT
-A FORWARD -s 192.168.42.128/25 -d 192.168.42.0/25 -o qmimux0 -m policy --dir out --pol ipsec --reqid 1 --proto esp -j ACCEPT
ACCEPT all – 192.168.42.0/25 192.168.42.128/25 policy match dir in pol ipsec reqid 1 proto 50
ACCEPT all – 192.168.42.128/25 192.168.42.0/25 policy match dir out pol ipsec reqid 1 proto 50
!fw3: Allow-
192.168.42.0/25 via xx.xx.x.xx dev qmimux0 proto static src 192.168.42.129
To explain the setup further more:
  1. RUTX12-1 is behind a Mikrotik router got online via WAN
  2. RUTX12-2 (client on location) is online via LTE
I think the routing tables looking false to me. On RUTX12-2 - table 220 he wants connect via 192.168.42.0/25 to our external Mikrotik IP. Since both routers can see and ping everything, the error must be somewhere here.
PS C:\WINDOWS\system32> .\TRACERT.EXE 192.168.42.85
Routenverfolgung zu 192.168.42.85 über maximal 30 Hops
1 Allgemeiner Fehler.
Ablaufverfolgung beendet.
Sry, its German and a Windows Client, but it stops with an error.
I’ll be somewhat busy today I’ll test a similar config and keep you updated.
Are you sure that 192.168.42.85 replies to pings ? Have you tested from 192.168.42.1 ? From 192.168.42.129 ?
The routes look correct, or I have missed something.
From 192.168.42.140, can you ping 192.168.42.1 ?
I finaly solved the problem by adding a gateway to my windows client. It could only be the clients fault, since the routers spoke to everyone.
Thank you for your input on this matter.
