OCPP klaida kraunant vienos fazės plug-in
Stotelė valdoma ocpp protokolu per EVCC programėlę. Kraunant vienfazį plugin hybrid kraunasi minimalia srove 6A. Kai bando didint gauna warning: Stoteles loge “Output current warning” EVCC loge: ERROR 2026/05/14 22:00:06 charger status: OverCurrentFailure: Output current warning resolved
Tai priverčia per nauja pradeti krovimo logiką. Kai prijungiu trifazį EV taip nesidaro. Arba prijungus plugin prie kito ocpp chargerio taip nesidaro per ta pati setup tam pačiam objekte ir per tą patį EVCC (evcc - Smart Charging ☀️🚘 - Intelligent Energy Management for Your Home)
[ocpp ] TRACE 2026/05/14 21:53:33 send A22A1442924: [3,"98540",{}]
[lp-1 ] DEBUG 2026/05/14 21:53:34 charge power: 1419W
[ocpp ] TRACE 2026/05/14 21:53:36 send A22A1442924: [2,"886649910","SetChargingProfile",{"connectorId":1,"csChargingProfiles":{"chargingProfileId":3,"stackLevel":5,"chargingProfilePurpose":"TxDefaultProfile","chargingProfileKind":"Absolute","chargingSchedule":{"startSchedule":"2026-05-14T18:52:36Z","chargingRateUnit":"A","chargingSchedulePeriod":[{"startPeriod":0,"limit":0}]}}}]
[ocpp ] TRACE 2026/05/14 21:53:37 recv A22A1442924: [3,"886649910",{"status":"Accepted"}]
[ocpp ] TRACE 2026/05/14 21:53:38 recv EVC2-99903: [2,"83461","Heartbeat",{}]
[ocpp ] TRACE 2026/05/14 21:53:38 send EVC2-99903: [3,"83461",{"currentTime":"2026-05-14T18:53:38Z"}]
[ocpp ] TRACE 2026/05/14 21:53:38 send EVC2-99903: [2,"1564331792","TriggerMessage",{"requestedMessage":"MeterValues","connectorId":1}]
[ocpp ] TRACE 2026/05/14 21:53:39 recv EVC2-99903: [2,"83462","MeterValues",{"connectorId":1,"transactionId":1778440112,"meterValue":[{"timestamp":"2026-05-14T18:53:38Z","sampledValue":[{"value":"6","context":"Sample.Periodic","measurand":"Current.Offered","unit":"A"}]}]}]
[ocpp ] TRACE 2026/05/14 21:53:39 send EVC2-99903: [3,"83462",{}]
[ocpp ] TRACE 2026/05/14 21:53:39 recv EVC2-99903: [3,"1564331792",{"status":"Rejected"}]
[ocpp ] TRACE 2026/05/14 21:53:41 send A22A1442924: [2,"1696507729","TriggerMessage",{"requestedMessage":"MeterValues","connectorId":1}]
[ocpp ] TRACE 2026/05/14 21:53:42 recv A22A1442924: [3,"1696507729",{"status":"Accepted"}]
[ocpp ] TRACE 2026/05/14 21:53:43 recv A22A1442924: [2,"98541","MeterValues",{"connectorId":1,"meterValue":[{"timestamp":"2026-05-14T18:53:41Z","sampledValue":[{"measurand":"Current.Offered","unit":"A","value":"16.0","context":"Trigger"},{"measurand":"Current.Import","unit":"A","phase":"L1","value":"0.8"},{"measurand":"Current.Import","unit":"A","phase":"L2","value":"0.6","context":"Trigger"},{"measurand":"Current.Import","unit":"A","phase":"L3","value":"0.0","context":"Trigger"},{"measurand":"Voltage","unit":"V","phase":"L1","value":"237.4","context":"Trigger"},{"measurand":"Voltage","unit":"V","phase":"L2","value":"236.0","context":"Trigger"},{"measurand":"Voltage","unit":"V","phase":"L3","value":"230.6","context":"Trigger"},{"measurand":"Energy.Active.Import.Register","unit":"Wh","value":"7748957.0","context":"Trigger"},{"measurand":"Power.Active.Import","unit":"W","value":"338.0","context":"Trigger"}]}],"transactionId":1778440113}]
[ocpp ] TRACE 2026/05/14 21:53:43 send A22A1442924: [3,"98541",{}]
[ocpp ] TRACE 2026/05/14 21:53:45 recv A22A1442924: [2,"98542","Heartbeat",{}]
[ocpp ] TRACE 2026/05/14 21:53:45 send A22A1442924: [3,"98542",{"currentTime":"2026-05-14T18:53:45Z"}]
[ocpp ] TRACE 2026/05/14 21:53:48 send EVC2-99903: [2,"2018138978","TriggerMessage",{"requestedMessage":"MeterValues","connectorId":1}]
[ocpp ] TRACE 2026/05/14 21:53:49 recv EVC2-99903: [3,"2018138978",{"status":"Accepted"}]
[ocpp ] TRACE 2026/05/14 21:53:49 recv EVC2-99903: [2,"83463","MeterValues",{"connectorId":1,"transactionId":1778440112,"meterValue":[{"timestamp":"2026-05-14T18:53:48Z","sampledValue":[{"value":"6","context":"Sample.Periodic","measurand":"Current.Offered","unit":"A"}]}]}]
[ocpp ] TRACE 2026/05/14 21:53:49 send EVC2-99903: [3,"83463",{}]
[ocpp ] TRACE 2026/05/14 21:53:51 send A22A1442924: [2,"2869825493","TriggerMessage",{"requestedMessage":"MeterValues","connectorId":1}]
[ocpp ] TRACE 2026/05/14 21:53:52 recv A22A1442924: [3,"2869825493",{"status":"Accepted"}]
[ocpp ] TRACE 2026/05/14 21:53:53 recv A22A1442924: [2,"98543","MeterValues",{"connectorId":1,"meterValue":[{"timestamp":"2026-05-14T18:53:51Z","sampledValue":[{"measurand":"Current.Offered","unit":"A","value":"16.0","context":"Trigger"},{"measurand":"Current.Import","unit":"A","phase":"L1","value":"0.8"},{"measurand":"Current.Import","unit":"A","phase":"L2","value":"0.6","context":"Trigger"},{"measurand":"Current.Import","unit":"A","phase":"L3","value":"0.0","context":"Trigger"},{"measurand":"Voltage","unit":"V","phase":"L1","value":"237.4","context":"Trigger"},{"measurand":"Voltage","unit":"V","phase":"L2","value":"236.0","context":"Trigger"},{"measurand":"Voltage","unit":"V","phase":"L3","value":"230.6","context":"Trigger"},{"measurand":"Energy.Active.Import.Register","unit":"Wh","value":"7748957.0","context":"Trigger"},{"measurand":"Power.Active.Import","unit":"W","value":"338.0","context":"Trigger"}]}],"transactionId":1778440113}]
[ocpp ] TRACE 2026/05/14 21:53:53 send A22A1442924: [3,"98543",{}]
[ocpp ] TRACE 2026/05/14 21:53:58 send EVC2-99903: [2,"203336582","TriggerMessage",{"requestedMessage":"MeterValues","connectorId":1}]
[ocpp ] TRACE 2026/05/14 21:53:59 recv EVC2-99903: [3,"203336582",{"status":"Accepted"}]
[ocpp ] TRACE 2026/05/14 21:53:59 recv EVC2-99903: [2,"83464","MeterValues",{"connectorId":1,"transactionId":1778440112,"meterValue":[{"timestamp":"2026-05-14T18:53:58Z","sampledValue":[{"value":"6","context":"Sample.Periodic","measurand":"Current.Offered","unit":"A"}]}]}]
[ocpp ] TRACE 2026/05/14 21:53:59 send EVC2-99903: [3,"83464",{}]
[ocpp ] TRACE 2026/05/14 21:54:01 send A22A1442924: [2,"220935259","TriggerMessage",{"requestedMessage":"MeterValues","connectorId":1}]
[ocpp ] TRACE 2026/05/14 21:54:02 recv A22A1442924: [3,"220935259",{"status":"Accepted"}]
[ocpp ] TRACE 2026/05/14 21:54:03 recv A22A1442924: [2,"98544","MeterValues",{"connectorId":1,"meterValue":[{"timestamp":"2026-05-14T18:54:01Z","sampledValue":[{"measurand":"Current.Offered","unit":"A","value":"16.0","context":"Trigger"},{"measurand":"Current.Import","unit":"A","phase":"L1","value":"0.8"},{"measurand":"Current.Import","unit":"A","phase":"L2","value":"0.6","context":"Trigger"},{"measurand":"Current.Import","unit":"A","phase":"L3","value":"0.0","context":"Trigger"},{"measurand":"Voltage","unit":"V","phase":"L1","value":"237.4","context":"Trigger"},{"measurand":"Voltage","unit":"V","phase":"L2","value":"236.0","context":"Trigger"},{"measurand":"Voltage","unit":"V","phase":"L3","value":"230.6","context":"Trigger"},{"measurand":"Energy.Active.Import.Register","unit":"Wh","value":"7748957.0","context":"Trigger"},{"measurand":"Power.Active.Import","unit":"W","value":"338.0","context":"Trigger"}]}],"transactionId":1778440113}]
[ocpp ] TRACE 2026/05/14 21:54:03 send A22A1442924: [3,"98544",{}]
[lp-1 ] DEBUG 2026/05/14 21:54:04 charge power: 1419W
[lp-1 ] DEBUG 2026/05/14 21:54:06 session energy: 5.311kWh
[lp-1 ] ERROR 2026/05/14 21:54:06 charger status: OverCurrentFailure: Output current warning resolved
Sveiki,
Koks tai EV / hibridinio automobilio modelis?
Galbūt turite arba galite gauti troubleshooting failą iš stotelės? Norėčiau pasižiūrėti, kaip stotelė bendrauja su automobiliu.
Jeigu negalite gauti troubleshooting failo, duokite žinoti – pabandysiu atkartoti krovimo žingsnius.
Pagarbiai,
Dominykas
Sveiki, automobilis kuri prijungus meta klaida Toyota RAV4 2024 plug-in su vienos fazes pakrovimu. Kiti kurie veikia gerai eGolf 2019 100kw krauna dviem fazem ir ID4 2022 krauna 3 fazem
