I’m developing a Central System communicating with chargers using OCPP 1.6J protocol. It communicates fine with Wallbox charger now and I wanted to append support for Teltonika charger. However test charger switched itself to “Unauthorized connection attempt” state what is unexpected.
Technical info:
Product code: EVC1200P4011
Network connection type: Wifi
Hardware revision: 000
Test scenario:
- Setup charger CONNECTIVITY following https://wiki.teltonika-energy.com/images/7/73/TeltoCharge_QUG_V2.4.pdf document.
- The OCPP URL: ws://some_lan_ip:8080/ocpp16/
- Charge point identity: CMD02
- wait for charger connection to Central System
Central System log (all messages):
Incomming REQ [CMD02]: [2,“1”,“BootNotification”,{“chargePointModel”:“TeltoCharge_EVC1200P”,“chargePointVendor”:“Teltonika Energy”,“chargePointSerialNumber”:“masked-away”,“firmwareVersion”:“v1.10.7”}]
Outgoing RES [CMD02]: [3,“1”,{“status”:“Accepted”,“currentTime”:“2023-10-26T18:51:20.2505262+00:00”,“interval”:30}]
Outgoing REQ [CMD02]: [2,“031487b1190c48d39220213f740b3f83”,“GetConfiguration”,{“key”:[“NumberOfConnectors”]}]
Incomming RES [CMD02]: [3,“031487b1190c48d39220213f740b3f83”,{“configurationKey”:[{“key”:“NumberOfConnectors”,“readonly”:true,“value”:“1”}]}]
Incomming REQ [CMD02]: [2,“2”,“StatusNotification”,{“connectorId”:1,“errorCode”:“NoError”,“status”:“Available”,“timestamp”:“2023-10-26T18:51:20Z”}]
Outgoing RES [CMD02]: [3,“2”,{}]
Incomming REQ [CMD02]: [2,“3”,“StatusNotification”,{“connectorId”:1,“errorCode”:“OtherError”,“status”:“Available”,“info”:“Unauthorized connection attempt”,“timestamp”:“2023-10-26T18:51:21Z”}]
Outgoing RES [CMD02]: [3,“3”,{}]
I tried to identify the issue cause and the solution (mainly following the OCPP 1.6 JSON guide - Wiki document) but with no luck.
Can you tell me what’s wrong and how to solve it?
