No "plug and chagre" function with OCPP? Problems with Authorisation in Remote Connection
I use a Teltocharge at home, OCPP works after setting it up to a server, but it always enables the Authorisation function, and it is very annoying.
Teltocharge Wiki says:
" When OCPP is enabled some of the configurations are hidden to avoid duplication from the server and the app.
  • Authorization slider (Authorization should be done through server)
  • Authorization enable/disable button (Authorization will allways be enabled when TeltoCharge is connected to the server) "
I would like to acess the charger remotely, but given its connecting to the app only with Bluetooth and not with WiFi, a VPN connection is useless. And with OCPP enabled I loose the convinience of the “Plug and Charge” feature.
Is there any solution to enjoy plug and charge and acess the changer’s data remotely?
Good Morning,
There is a possibility as we have custom command to make charger “PlugThenCharge”
Please let me know your devices Serial number first
Br,
Thats great news!
My S/N is: 1127156465
Thanks!
Gabor
GeriSoft should forward the document to you.
If they will not do it, please write me an email to: support.energy@teltonika.lt
Yes, they forwarded the document, thanks!
But according to the information, I have to set the “PlugAndChargeNoAuth” command to value : 1, and I’m stuck here.
I just installed an OCPP integration to my Home Assistant. The integration recognizes the charger, gets info about changing, but there are no options to customize settings.
Is there any free OCPP server option to monitor the Charger and I’am able to set the needed parameters? I’ve found a list of compatible providers list, but seems they all sell OCPP as a monthly fee service.
Thanks,
Gabor
Could you please try with: https://monta.com/
When you will change this setting you could try to reconnect the charging station back to your Home assistant
Br,
Thanks for the link, Monta works fine! From a PC login, I was able to change the needed option, Plug & Charge works as charm!
